Cube Maintenance
Should we clean or lubricate our Metmo Cube? One of my cylinders was stuck and the other moved very slow after a few weeks on non-use. One cylinder moved enough that when I pushed it down with some force the other pin came loose. It works fine now, but just curious if there is some maintenance I should layer in (e.g. silicone lubricant). Thanks!
Hi, we made a helpful video a while back on how to care for your Cube, let me know if this helpful! https://youtu.be/04v0xGVfFkw?si=Bo8k–HIibp7dEbV
